ok jag har ett par idéer om hur jag kan montera det främre blinkers på triple tree..
Jag har kit från Drag Specialities ur den FatBook pt # 2020-0347 ($ 20) sidan 691..Jag har redan haft det pulverlackerat..it gets bolted to the lower tripletree and replaces the original pinch bolt.
The other idea is to use the rear indicator blanks,drill another extra hole,bolt the indicater to the lower hole and then remove the lower pinch bolt,slide the blank plate in the slot behind the triple tree,then bolt the pinch bolt back up to the required torque..
sorry 'bout the english guys..just giving my brain a rest LM;
