Ok får nog göra det:)
Fast avsaknaden av multispark borde väl inte underlätta start eller frv;
"Den som kickar får se"
Hittade det här på nätet,Sista meningen skulle jag gärna få förklarad för mig:
Kick Start Capability
The Model 1005 is primarily intended for electric start applications. However, Rev 7.0 units (manufactured after January, 2006) can be programmed for kick start mode by using our PC Link Evo software and optional USB interface. If you order on-line, you can add a note stating that you require kick start capability and we will program the unit for you at no extra cost. When programmed for kick start mode, the unit has zero cranking delay and a 30 second timeout before coil current shutoff.
