Information gällande CAN-BUS elsystem
Passar på att informera att de senare Harley-Davidson Dyna 2012-upp samt Softail 2011-upp INTE längre behöver loadEQ för LED-blinkers! Det nya elsystemet CAN-BUS tar hand om detta enligt BADLANDS, USA.
Ska du däremot sätta på custom handkontroller, reglage behövs en by-passbox.
Saxat från ett e-mail från Badlands, USA
All information indicates a Load Equalizer is not needed with the new CanBus system in order to simply convert to LEDs. We have been able to confirm this on a couple bikes ourselves, and we are working on introducing a new run/brake/turn module for the "normal" light applications. The only time we have seen any issues is if the bike is having the lighting arrangement changed, such as by removing the tail light. In such a case, the BCM needs to be reprogrammed by a Harley shop using the Digital Technician.All information indicates a Load Equalizer is not needed with the new CanBus system in order to simply convert to LEDs. We have been able to confirm this on a couple bikes ourselves, and we are working on introducing a new run/brake/turn module for the "normal" light applications. The only time we have seen any issues is if the bike is having the lighting arrangement changed, such as by removing the tail light. In such a case, the BCM needs to be reprogrammed by a Harley shop using the Digital Technician. /Dan, Badlands Inc
Hampe15
Redan dyna 2012 har det nya CAN-BUS systemet, kollade upp det när jag bytte till LED. Vara bara koppla in å köra http://harleyforum.se/images/smilies/smile.png
