D&D CUSTOM BIKE OF THE WEEK--Richard Krall built a custom Harley-Davidson Night Train with high performance D&D exhaust. The hot rod scoot you see here contains a one off Suzuki 750 front end, slotted aluminum Fat Bob front wheel and a modified the gas tank using the hinged air box off a V-Rod.
One item Richard took off the shelf was the black 2 into 1 Fat Cat pipe. The pipe was designed in the dyno room to extract the most performance possible. The power is made off idle and when passing, meaning that power is made early instead at the very end of the RPM range. Depending on the Harley model, enthusiasts can choose from 1 to 3 sound profiles.
Get more details on D&D Performance Exhaust pipes.
